Ana içeriğe geç
The Kyros MID7024 is an android tablet released in April of 2011.
2 Soru Tümünü görüntüle
Why does my screen go dark so quickly?
My tablet screen goes blank after a few seconds, why does it do that and how do I change it?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
The screen will often go dark from inactivity but you can also adjust the brightness settings according to your preference.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
The screen may go dark faster than desired if the device is in a power save mode. Check the device settings to see if this is the case. If this does not help, check the device settings to see if it allows the user to select the amount of time that can pass before the screen goes dim/dark.
Puan 2
3 Comments:
How do you change the amount of time it takes before the screen goes darkness
tarafından
I wish I knew!
tarafından
Hi there! I don't know if this still helps, but maybe check your settings, and search for power settings in the settings search tab. You might get the screen time preference under that.
tarafından
Yorum Ekle
Instead of I phone users offering advice, why doesn’t APPLE provide a solution?
Puan 0
1 Yorum:
A “score”?! I need an answer, this isn’t a game.
tarafından
Yorum Ekle
Yanıtını ekle
Kyle Williams sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 6,007
