Hello everybody! First of all i wanted to say that what you are about to read is for SONY ACTION CAM HDR-AS30V and i don't know if the solution is applied for other models too.
I had the same problem a week ago, after using the camera 3 years with no trouble at all. The above solutions you all described didn't work out for me so the wait problem still appeared. I found another solution that worked for me and finally solved the problem. After many ours of trying to figure out the problem i went to the conclusion that the problem was the vibrations on the camera. So here is what i did.
I unscrew the two little screws on the bottom lid of the camera and slide out the internal of the camera of its case. There are many videos on youtube of how to do this and it is very easy!
Then i unscrew the two Little screws that holds the lcd display. I moved a little and re-positioned the display in its place and screw tight again the two screws. I slide the camera back in its case, screw the two screws on the bottom tight , put the micro sd card and battery in and started the camera. Works great !!!! i tested with vibrating while recording and no problem at all!!! So all you have to do is to screw tight the screws of the camera to eliminate some vibrations that causes the WAIT indication keeping flashing!
I hope it works for you too, because that little camera worth its money !!!
Please reply if this solution worked out for you too.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
2 Yorum
hi i wanted to inform you..
it was all about hardware..
i used the cam on my handbar that is why i damaged the coneection between lens and cam..
thay changed it for 50$
it is ok now..
if you will use it on bike pls use it on your helmet!!!
ferhatucankus tarafından
Hello!!! Sony HDR AS30 did not work when REC bottom pushed! On screen blinks text WAIT WAIT WAIT!!! Problem fixed.I took battery out of camera. Next i opened camera(two screws).After i unscrew lcd module screws(two) i open cameras body(motherboard and lcd module sides)and unplug lcd module side from motherboard.Than i check all the flex cables(lense cables-big with lense and motherboard and small which connects with motherboard)and i saw that two of them are not perfect in socket(sorry i'm Latvian.If there are some mistakes in english,sorry).I reconnect lense cables both side of cable and small cable also (very carefull!!! Be aware!!!).Than i returned them back each-very carefull and in perfect position!!! Than i put back lcd module panel to motherboard also connect flex cable and screw both screws back.Than i put in battery and mini sd card and SO!!! Camera works perfectly!!!! Push record and all is working perfect!!!!! Cameras issue was flex cables which were not in their places perfectly!!!
patrx tarafından
