Ana içeriğe geç
not charging not detected by pc
I have an Iphone 6 plus, it just stop charging and is not detected by computer, put new fully charged battery (it turns on but is not charging and not detected by pc) try new charger cable, new ac adapter, even new charging port. nothing working please help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
i have tried to use different cables, different USB ports, different PCs. all can't work on my iphone 6 plus. No detection and not charging by PC. But when i tried to connect my ipad to PC, with the same cables, sames USB ports, same PCs, it works. I reckon is the phone problem. could it be the phone setting problems? Please help.
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
easiest indication of bad chip is to disconnect battery. then connect charging cable via mains power to charging port and see if Apple logo appears . if it does then its ok, if not then indicates bad chip
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
my iphone SE charging through wall mounted charger point but not through my mac book USB port. When same lightning cable connect to my other IP6S through same mac book port it got charging even same USB port too. Could anybody help me on this regard.
thanks in advance.
Abu M
Puan 1
Yorum Ekle
I would look into the U2 iC chip on the board!
Known good battery + Powers on = Good power management chip
No Computer recognition or power through known good port = U2 iC.
Hope this helps!
Puan 0
Yorum Ekle
Hey,
Have you tried cleaning your charging port?
When the cable is plugged in, it should be flush with the phone.
If it's not flush, that's where your issue is.
If not look at the "U2 iC chip" like @jmicks22 stated.
Hope this helps
Puan 0
1 Yorum:
YESSSSS! Definitely try to clean the charge port of lint or dirt! I cant tell you how many times a phone comes in to me and i just use a pick and remove lint... BOOM problem solved!
tarafından
Yorum Ekle
Make sure you are using the original charger and USB cable that came with your phone when charging your device. Try plugging the charger to a different power source and see if the issue still occurs. You should also try to use a different USB cord and wall charger to see if the charger is causing the problem.It sounds like you have an issue with your charging cable. I would try finding someone that you can try theirs, or go to a store that sells iPhones and ask them if you can try their cable to test it out and narrow down the problem. Obviously, if the problem still persists with a different cable, then it's the phone that's the problem. I have a feeling it's most likely the cable. Good luck.Truth be told, I never charge my iP6 via USB. I carry a spare charger in my briefcase if I need to charge at work and when at home, I charge via wall charger only.
Puan 0
Yorum Ekle
The issue, most likely, is a bad tristar ic. If you replace this chip it should work just fine.
Puan 0
Yorum Ekle
Yanıtını ekle
myaccell sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 4,647
