Turn on 2 beeps continuos
Turn on can here running two beeps continuous black screen
Bu iyi bir soru mu?
Bu iyi bir soru mu?
weezall97 the 2 beep POST code indicates that your computer No Memory (RAM) detected. The official cause of this is a Memory or Memory slot failure. You could have a bad memory module or a bad slot. Before you replace the memory, I suggest you reseat your memory. If that does not fix it, and if your able to see the Dell Logo at startup, press F12 at that page, and select Diagnostics, and run an extended diags on your computer.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 537
