A few months ago I noticed my iMac acting strange, with my screen not refreshing and everything on the screen would have residual images. I did some searching on the apple boards, and others were saying it has to do with the fan not working properly and overheating. They recommended I used smcFanControl, which has done the trick so far. Is there a permanent fix to this? Something I can replace? Appreciate any info.
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
5 Yorum
Does smcFanControl display current temperatures for processor and drives? If not, you should add Temperature Monitor, or some other tool, to display, monitor, and alert you to temperature issues BEFORE serious damage is done.
Thanks for all the respones. I think at this point, smcfancontrol is doing a ^^*@ fine job, so will ride that wave until I have to forcefully re-assess the problem. Opening the iMac case is a huge pain in the @%$, and I can't even imagine attempting it!
Same problem here. I've had multiple issues with this computer and am quite *#%!#^ that Apple continued to ignore and deny this problem.
The SMC fan control does help, but it's hard to have piece of mind jacking up the fan speeds much higher than they were suppose to be run. Apple should have offered to replace this faulty graphics card, since it is a known issue.
I should also mention that even with the fan control installed and running, I still can't watch a video without freezing and glitches.
Oh, other common problems associated with this model: left side of screen is brighter than the right (bad for graphic designers and photographers especially), the over all screen brightness is WAY too bright for any realistic calibration (without the purchase of expensive software), and the cd/dvd drive is a faulty one; mine broke within months of soft use.
Apple sure hasn't left a good impression for this first time mac owner. They are over priced pieces of !^@^ to be quite honest.
Fully agree. you can buy a far superior PC for far less than half price here in Australia and you have a far better experience with a more powerful and easier to use OS.
A year ago I had to replace the failing Graphics board (thanks iFixit for the guide). It was both expensive and time-limited, because after less than a year the new GPU began showing same ill behavior.
What I've learned.
First and foremost: CLEAN thoroughly the heat dissipation system. Bottom and back ventilation holes, all internal fans, Heat-sync metal parts. Open the machine, and clean it up. On my machine everything gets clogged with dust.
Second - I've been using both smcFanControll and HDD fan control to increase fan speeds beyond Apple's standard, again, to reduce the temperature on sensitive electronics. This did not prevent the second failure.
Last - Only use your iMac in a cool environment. This specific model is susceptible to heat more than other models.
When I replaced the GPU, I also replaced the hard drive, and unfortunately I broke the original thermal sensor - hence my use of HDD fan control (using the hd's internal sensor instead).
fyi I can share my experience with this machine and this same problem.
until recently I had this model iMac 24" 2.33GHz with nVidia GeForce 7600GT graphics card. it had intermittent heat-caused graphics problems, specifically:
a) occasionally, random horizontal lines on the display or within a window would become corrupted, or
b) when running 3D intensive apps, there would be massive graphics corruption over the whole screen, eventually leading to a severe random crash and lockup of the machine.
the problems would only occur when the machine was running hot. Problem a) could occur no matter what application was running, even just within the Finder. usually just single horizontal line would be corrupted.
since I had a month left in my 3 yr AppleCare warranty I brought it into the AppleStore. they confirmed it was a hardware problem and replaced the logic board and CPU fan which seemed to be running a bit slow. we reproduced the problem in-store by running a lot of graphic-intensive apps, a bunch of flash-heavy websites, and even partially blocking some of the airflow vents on the machine.
after replacing the logic board and fan, they still said they weren't satisfied the problem was solved and ordered a replacement graphics card. (this matches what I have read on various internet forums - that this problem is due to the graphics card in this model iMac)
Unfortunately they had problems sourcing a replacement graphics card and after many weeks of waiting they offered to either continue waiting for the replacement (unknown ETA), or replace my 3yr old 24" iMac with a brand new 27" 3.06GHz C2D machine. you can guess which option I chose :) AppleCare FTW
anyhow just fyi, this model does appear to suffer graphics card problems under heat. if your warranty has already expired, then yes smcFanControl seems to be one way you can at least mask the problem. Otherwise, perhaps try replacing the graphics card. I've not looked at the graphics card myself, but apparently they have a MXM (Mobile PCI express Module) interface. good luck.
I had multiple problems with the iMac (late 2006 Intel Core 2 Duo 24")after a few years of use. The computer was running extremely slow even after all manner of fixes including bigger HD, resets of everything, Drive Genius fixes, etc. Then it started freezing in mid opening of applications with a distorted image of a half opened application plus lines through the screen. It became unusable with no fixes from Apple Store recommended other than possible logic board.
I opened it up again and thoroughly cleaned with compressed duster - fan blades, ducts, conductor and cooling fins. In addition the GPU was blown out as well as possible. Finally the gap in the duct between the CPU cooling fan outlet and the copper heat conductor was sealed with aluminum tape and a bit of tape was used around the openings in GPU to keep air flowing through it. (Note the iMac 24 MA 456LL/A that I have is quite easy to open. You do not have to use the credit car to pry back the levers found on some of the other iMacs.)
The unit was reassembled and smcFanControl was downloaded and installed. Before installation the GPU was running over 105˚F with no heavy use. After smcFancontrol even with heavy use the GPU rarely went over 98˚. The problems have disappeared and all seems well. The cost of repairs was $4.50 for a roll of tape of which I used about 6".
This is a question and follow up to my Feb, 2010 posting. After about 2-years of reduced freeze ups using smcFanControl the problem has come back regularly.
Question: I have a nice 21.5" monitor that I use for a laptop. Will use of the monitor on the iMac avoid the graphics card problem caused by the bad GPU? I would use it with the DVI connection on the monitor.
So will replacing the logic board/graphics card permanently fix this issue? Did they redesign the LB? Or if I have the GB replace, will I run into the same issues as before?
1 Yorum:
no, they did not redesign the layout of the logic board. there were problems with the "non faulty" series of the gpu - so it could always come back - but, there are many companies that could fix the gpu, some are simply reflowing the gpu - this can work - or not, some had no problems at all, others within a few days after the fix. other companies are reballing the original gpu and solder them back - this would work. and the most expensive repair would be a new gpu. replacing the logicboard is normally a extremely pricey fix
There are issues with the gpu in that model. It will overheat and burn off or cause other parts to decay fast like capacitors. The caps go as soon as you start seeing noise in the screen (ghosting, static in picture, hissing sound from the system that changes with picture movements like a window or mouse cursor) A replacement card is the only option if you do not know how to repair smd devices (surface mount devices on the board) The caps are the silver aluminum things. My guess is a design flaw in the heat sink or thermal compound.
There are confirmed reports that the heatpipe part of the heatsink is failing. Small pinholes have appeared in the heatpipe. This ruins the heat transfer capability of the heatsink and makes the GPU overheat. By simply replacing the heatsink the problem is fixed.
I also used smcFanControl and it fixed my same problem with the heat-caused graphics problems. I also placed smcFanControl on my Mac Mini that's in a little shed that the sun beats on in the summer, It fixed my lockup problem on the Mini
You might want to do a little cleaning, just recently, my ATI Radeon X1900 XTX in my pc was overheating, and acting up. I dissasembled the heatsink for the card, and cleaned the dust out of it (and there was quite alot of it, since i've had it for 2 years) and after that, removed the heatsink entireley to re-apply the thermal paste(i used artcic silver 5, the best stuff around) and not the card runs like new, the graphics card heatsink should be removable, and if your warrenty is expired, apple can't really help, so if you want to take apart your iMac, try cleaning out the dust, from all of the heatsinks (even the cpu) and then remove them and re-apply a thin layer of artic silver 5 (a tube costs about $10 at radioshack) and then put it back together.
1 Yorum:
Heatsink Removal and Replacement (R&R) is not for the newbie. Be extremely careful, and read up, you could be worse off than when you started if you end up with air bubbles where there should be paste.
I've been having the same problems with my Imac 2006 with the NVIDIA GeForce 7300 GT card. I installed SMC Fan Control and it helped, I cleaned the fans 6 months ago.
Anyway I took the computer apart again and cleaned it throughly. When I took apart the fan on the left side, unsnapping the duct cover, there was a large amount of dust on the radiator fins of the graphics cooling heat sink. I estimate it was plugged about to 50%. I vacuumed it out and cleaned the fans, it seems to run cooler now as more air flow gets across the heat sink....
There was also a bit of dust on the air intake on the bottom of the computer.
Same story --- my 2.16GHz 2006 white iMac started to show all kinds of ill behavior (graphics noise and strips, completely garbled graphics, and system-hangs) all related to heating.
Following the tip I found here -- I installed smcFanControl, and it improved things for a while. However, it deteriorates over time, and now I can't use the machine unless the air conditioning is turned on in the room.
It starts to show signs of malfunction as soon as smcFanControl reports anything over 31celsius (round 90F).
Our area is very dusty, and I'm quite sure some cleaning can improve things again. However, I'm quite sure it can't SOLVE things.
In addition --- the internal superDrive stopped being able to eject discs, which again is something reported here. Up until now, I couldn't find reasonably priced internal replacement drive -- but now I saw some ~$90 used drives here.
I guess it is time to open the machine... My questions are:
1. Are there any detailed tutorials for replacing the GPU card?
2. Did anyone actually replaced his GPU, and (the iMac) lives to tell the story?
3. Where and How can one purchase the right GPU card for this rather old machine?
4. Are there any specific recommendations here for replacing the internal HardDrive (upgrade for bigger storage) to something which also RUNS COOLER ?
I never took apart this iMac, and the tutorials for replacing the optical drive don't exactly encourage me to try. Prying open the case seems a little dangerous - I could break some of the levers, or something).
I dealt with lot's of electronics in the past, but I remember macs to be a delight to dismantle (orignal Macs, Mac II series, Quadras, PowerMacs, PowerBooks G3 G4 and G5 Towers, Intel Mac Pro's and many others --- however, this seems to be very different, and very risky ---
1 Yorum:
I Ramped up my fans to 5600 RPM and running smooth ever since 24" iMac 2.16. Sad thing is this thing sat for 3 years because apple wanted to replace my logic board for almost 1k.
I am abusing the heck out of it trying to make it crash but, still smooth.
I also have the above problem with my 24" Intel Mac but am having a lot of trouble downlading smc fan controller onto my mac? It is either a windows based software that runs on an Intel mac under windows or a mac product that refuses to install. Once it requested last volume when trying to unzip? should I be using 2.2.2 or 2.4 version with Snow lepord?
I had purchased a 27 inch I mac circa 2009 or 2010 the first time that they were released. I think it was a core i7 with 4 cores and a 4670 or 4600 series gpu. The v ram was 1 gig and 1 tera hard drive. Don't recall the cpu. It may have been 2.8 or 3.2. I know that I was very happy with it the night before. What started my trouble is the next morning. I think I burned a dvd. 4.7 gigs. The screen started flickering. Went to black than back to white and black dots dancing. This went on for 5 minutes and the screen came back. I was good for hours. Just that first couple of minutes when waking up in the morning the computer that is after putting to sleep the night before and burning a dvd in the morning. This freeque me out. I return it. I exchange it 3 times with various other quality issues before I gave up and opted for a laptop. The laptop had all sorts of issues including external video flickering on a monitor. Two years of constant visits to apple store. One year in I had an exchange for a newer model. The newer model had logic board changed and fail similarly. About 6 months out of warranty I had a total hard drive failure. Apple refused to fix. I buy a hard drive at Micro Center for 79. The original 750 the new 1 tb drive. Apple refuse to even loosen the screws on the old hard drive. Special tool was needed. They did it for me at micro center for free. The only thing apple would do is help me reinstall the OS from their archive. The computer I sold on Craigs list for 1/3 the price I pay for or close to that. I by the mac book for 2800 sold for 1100 on crags list. So a bit over the 1/3 mark. Sad story is mine. Mind you while the hard drive is failing in a 12 month period the apple genius bar tech kept having me reinstall the software blaming on software problem for corrupt areas. This should have been the change of hard drive while it was under warranty. Shame on apple. I also filed with the City of Chicago consumer agency that told me there was nothing they could do for me. So apple is above the law. What can some one like me do with no real cash to fight the big dogs. I just have to except that big corporations with team of lawyers can get away with anything. All I can do is blog about this.
Same overheating problems with imac g5 white 24inch nvidia 7300 gt. Smcfancontrol stop it to crash and those graphic detail but aplication like chrome with a few windows opens specially videos running cause those graphic detail errors to come back. for years i suppose it was graphic card problems and i was thinking on upgrade to 7600gt, but the cost of it is too high (300$) i Havn't clean the dust also uncheck the thermal paste in 6 years. i hope this help me, if does i will sell this machine a soon as posible.
5 Yorum
Dave tarafından Paylaş
J.
synfony tarafından Paylaş
Derek Kimball tarafından Paylaş
Pete tarafından Paylaş
I have the same issue, for the second time.
What I've learned.
Motti Shneor tarafından Paylaş
