Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Soru Tümünü görüntüle
iPhone 5 doesnt power on
Hello!
my iphone 5 was working perfectly well after i did battery replacement, however, two days down the line, i decided to test whether my bro's battery is still working so that i can use it should mine have some problems since he left it at home. i then started off and tried to take mine out. very unfortunately, i happened to apply more force on the battery connect trying to pull it up with my nail so much that i broke this thin cable from the battery. I then made a stupid decision to try solder back that cable together, i scratched it, soldered it and tested any shot with the multimeter, i got none. I then put back the soldered battery(the new one that i just put it)...but the phone couldnt charge, it kept looping showing apple logo for a few secs and off again...i took it out, tested the connection(continuity) and any short,and put it back again, there was no luck! i then bought a new battery, i tested with multimeter to ensure that it had a litle juice, i then put it in, the case was the same, there was looping, and i cant even get to recovery mode!
can anyone help me out as to what can be the possible problem caused by all this mess? could it be that the phone had been shorted by the soldered battery. what can be affected by the wrongly connected or shorted battery in an iphone circuitry?..i am really confused and full of regrets!...help me out please!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
4 Yorum:
Did you do any other repairs on the phone besides the battery replacement?
tarafından
not at all! i havent done anything yet!
tarafından
Have you tried holding the home button and the power button at the same time for about 20 seconds ? That might help.
tarafından
Yes i tried that countless times but stil, no luck! I think its a hardware problem! so now the question is, what can be possibly affected if there is a short on the battery connector or if any of the battery connection lines get swaped?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Probably the battery connector or something near him...go to store and try replacing it or try to find trough the scheme what youve damaged.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
lesz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 89
