Ana içeriğe geç
Released March 1, 2015. Shreds documents, credit cards, and other sensitive information into small irreparable fragments for information security.
4 Soru Tümünü görüntüle
Soru Kapandı
How do I fix paper jam
Got a nasty paper jam and i cant clear it.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The easiest way to clear a paper jam would be to move the power switch to "Reverse" while pulling on the jammed paper. Once removed, you should then remove the top assembly from the bin and remove any shreds of paper that may still be stuck there.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
There is shredder oil that you can use to soak the paper. I do not have the type of oil but I am sure you can google it. That should help, just hope the jam was from paper and not staples or plastic.
Puan 3
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 152
