Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
USB charging dock connector flex damage cause no sound on speaker
I was changing rear housing for my iPhone 6 last night and tore a tiny area of the Dock connector flex cable as indicated in yellow in above photo. I thought it would not affect anything because it is small and it doesn't look like an important passage.
However, I believe this resulted no sound on speaker. Is the cut in the way between the speaker and board?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
That cut will cause the loudspeaker to stop working as it cuts the connection on the charger port flex cable assembly. You will need to replace the whole charger port flex cable which isn't that expensive.
You can get the part from here:
iPhone 6 Lightning Connector and Headphone Jack
Guide to replace it is here:
iPhone 6 Lightning Connector Assembly Replacement
iPhone 6 Lightning Connector and Headphone Jack Görseli
Ürün
$19.99
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Thanks, I've order the the assembly.
tarafından
Yorum Ekle
Yanıtını ekle
Wooran Lee sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 605
