no picture but good sound and channel changing
no picyure but normal sound and channel changing on Mistubishi model LDTV152
Bu iyi bir soru mu?
Bu iyi bir soru mu?
jacapozzimd sounds like a backlight issue. If your screen is dark but still displays the menu your can try a reset first . Service Level Initialization
Is designed for Servicers, and resets all options and A/V settings to factory defaults. This initialization is activated through the TV’s Option Menu, showing Figure 3-2.
Service Level Initialization Procedure:
1) Use the Remote control an press “MENU-2-4-7-0” activates the Option Menu shown in diagram
2) Use the Up & Down buttons to highlight INITIAL.
3) Press ENTER (resets setting to factory defaults).
If you cannot see your menu then use the LED diagnostics:
The two front panel LEDs, POWER and STATUS are usefulness determining the cause of a malfunction.
Whether the TV is On or Off, the STATUS LED is normally Off. Table 3-1 shows the normal LED indications if no problem exists.
Attached images describes the abnormal LED indications when a problem exist. If the STATUS LED is steady Red it indicates a circuit problem. Possible causes are:
• Short circuit
• PWB problem
• LCD Panel
• Disconnected or loose cable.
Use the following Error Code feature to further help isolate the problem.
Error Codes
To use the Error Code operational check the TV must be in “Shut Down” and not have been switched off. If the TV has been switched Off the code automatically resets to “12” No Error.
Error Code Activation
While the TV is in “Shut Down”:
• Press and hold for 5 seconds, the top panel “INPUT” and ‘MENU” buttons at the same time.
• The “POWER LED” will start flashing.
• It flashes the value of the MSD (tens digit) of a two digit Error Code.
• There is a 1/2 second pause then the value of the LSD (ones digit) is flashed.
• The value of the Error Code is repeated five times.
Example:
If the LED flashes 3 time, pauses, then flashes 5 time, the error code is 35.
The Error Codes for the new LCD models are listed in Table 3-3.
Error Code Cause Most Likely Failure
12 Normal off No Problem detected
27 Inverter short detected PWB-POWER - No 24 V at PC-Pins 1~5
28 FPGA download failure PWB-MAIN
29 FRC communication error PWB-MAIN
41 3.3VS or 5VS STANDBY-SHORT PWB-MAIN
44 LVDS Cable connection detection Loose LVDS Cable at PWB-MAIN (VR) or Panel Assembly
48 3.3V PON-SHORT PWB-MAIN
59 Panel 12V Short PWB-POWER - No 12 V at PB-Pins 9 & 10
So if that does not yield any results, than you will have to take your TV apart. Unplug it of course, remove the back and take a lot of pictures and post those with your original question. For that use this guide. Again right now you seem to have issues with either your power board or your inverter.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 484
2 Yorum
Can you display the menu on the TV properly? Or is the screen constantly black with no image from the time you power it on?
BurnieG tarafından
constantly black
karldrumm tarafından
