Ana içeriğe geç
Philips Taşınabilir DVD oynatıcı, PD9000/37 model numarasıyla 2011 yılında üretilmiştir.
Volume control not working
Sound is working through the speaker but it's stuck on maximum volume. Turned the volume wheel but volume won't change. Bought used, so I don't have the remote or manual. Is there a way to fix it? Thanks in advance!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Here is a link to the User Guide for your player.
http://download.p4c.philips.com/files/p/...
If you are trying to use the Volume control on the side of the player (p.13 of the manual) to adjust the sound level and it is not responding, it may be that the control is faulty or perhaps there may be a wiring or component connection problem
Here is a link to the Ifixit guide on how to open the player so as to gain access to the inside of the player and then to the volume control, which should be able to be seen at about Step 3 in the link below, so that you can ascertain what the problem is.
Philips PD9000 37 Tuş Takımı Değişimi
Hopefully this is of some help.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thank you so much! I will try the suggestions with success hopefully and follow up :)
-Gina
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Gina Aguilar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 39
Her zaman: 6,745
