Ana içeriğe geç
Stripped, lower cost version of the XFX 680 chipset.
3 Soru Tümünü görüntüle
RAID 0 gone bad.
any ideas to get a raid 0 array working again? the drives are fine and all the data is on them, but raid doesn't want to recognize them. someone suggested rtools, but a demo version only lets you recover 64kb files. key? other options?
Bu iyi bir soru mu?
Puan 1
1 Yorum
did I mention this is for an XFX board?
read: running Windows 7.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If the RAID set is broken, yet you can read the data, your best option is to copy off what you can/need.
The only way I know to get a broken RAID 0 set back working is to set it up as new - which means the existing data is going to be erased.
RAID 0 is all about speed and performance - there is NO data redundancy... Depending on how your RAID controller and RAID 0 set was created, you may only lose files split across the drives (JBOD mode). If your RAID 0 was in Striped mode, you will probably need pay for something like rtools.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
that's what I figured, I'm trying to decide if rtools is worth it because I don't actually remember what's on them. If I knew, I'd be able to decide. Oh you, impasse!
tarafından
tarafından
R-Studio is a great thing. You will certainly be able to use it for other things beside this problem.
tarafından
Yorum Ekle
Yanıtını ekle
tabormeister sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 8
Her zaman: 4,360
