Garmin watch incorrect time
My Garmin Forerunner 630 now shows the time 8 hours and 11 minutes behind the correct time. That could be the time the battery was flat. I then had real difficulty pairing with my iPhone but it's now paired.
I have done soft and hard resets of the watch and removed and reinstalled Garmin Connect. I've changed time zones on my iPhone. That changed the time on my watch but it's always out 8 hours and 11 minutes. I've manually changed the time on my iPhone but that had now effect on the watch. I've done multiple data transfers with Garmin Connect but that didn't help.
Any thoughts?
Update (04/29/2016)
Found how to reset time under settings and clock on the watch. Obvious, really
Update (04/29/2016)
Actually, it's not fixed. The question remains.
I can manually set the time, but if I set it to automatic it shows the wrong time.
Any thoughts on fixing the automatic feature?
Bu iyi bir soru mu?
14 Yorum
Thanks jayeff! I wrongly thought the time was from the phone not the satellites.
Rob Dunn tarafından Paylaş
I tried but it doesn't work.
If the hour sync by itself my hour is wrong but my appointment have the right time. If I manually set the time all my apps have the wrong time...
what can I do
Sara tarafından Paylaş
Bummer watch! I can't seem to fix the problem of my Forerunner 235....I find it too complicated! I can't figure out how to set the time. Please help! I've tried to set it via GPS but still can't correct it.
spiros85 tarafından Paylaş
Hi @spiros85
To set the Time Manually
Select Menu > Settings > System > Clock > Set Automatically > Off.
Select Set Time, and enter the time of day.
By default, the time is set automatically when the device acquires satellite signals.
Time Zones
Each time you turn on the device and acquire satellites, the device automatically detects your time zone and the current time of day.
Check that Select Menu > Settings > System > Clock > Set Automatically > ON.
If you are not getting the time set automatically, go outside in the open and wait, it could take up to 2-3 minutes to acquire satellite signals to set your watch. If the time hasn't automatically been set after this amount of time (assuming that you have the Time automatically set to ON then there may be a problem with the watch's GPS function..
jayeff tarafından Paylaş
I was having the same problem, although I reset the time, it continually would change to a time which was off by several hours (not sure how many). what I found was that I had synced and loaded a new version, however when I unplugged my garmin and was asked if I would like to "update now", I said no because I was going for a run. Garmin connect showed I had the most current version, but my watch showed a prior version. I had to go in and manually select "update" or maybe the options is "install", once that was done, the time reset by gps
darden1 tarafından Paylaş
9 tane daha yorum göster
