Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
touch screen systematically unresponsive after any wake up?
Hello,
I replaced my iphone 5s screen and afterwards I have this systematic issue. Every time you hit the power/home button to wake it up, the touch screen is unresponsive. Simply pushing the power button twice (sleep then wake back up) results in a fully responsive and functioning touch screen. This occurs basically any time the phone has been asleep for longer than a minute - I haven't systematically figured out the exact time.
Does anyone have any ideas what is going on? I have turned the phone off and back on, same issue remains, and it has persisted for the last week.
Thank you for any assistance,
Jake
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hey jolson1129, disassemble and reassemble the display. Here is the guide for that. Also try a hard reset by holding the power and home buttons together until the screen turns black and the Apple logo shows up. Also if it doesn't work then the display might be faulty and you might have to replace it.
-Let me know if this helps.
iPhone 5s Screen Görseli
Ürün
iPhone 5s Screen
$34.99
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
I think it's either a force restart, or its lacking in gigabytes, and just needs more time to think...
tarafından
Thanks for the responses.
It's not a time thing (as in memory like you suggest), I can wait however long after pressing the button and the touch screen. Also, the issue didn't exist before installing this screen. Hard reset didn't work. I'll disassemble and reassemble, but I don't understand how this could be a connection issue - does anyone have any idea what kind of issue it is? Almost seems like a capacitance issue. Could help to suggest a fix if someone had an idea on the cause.
tarafından
@jakeo I think the display is faulty. To confirm this, you should reassemble and disassemble it. If the issue still persists then you should replace it.
tarafından
Yorum Ekle
Hi jolson1129,
I'm having exacly the same issue with a Iphone5s, did you you ever found out what was the easy fix for this issue? I just restored the phone and keeps doing the same.
Cheers
X
Puan 0
1 Yorum:
I don't remember what I did, I believe I just I'll disassembled and reassembled. I believe that solved the issue.
tarafından
Yorum Ekle
I have almost exactly the same problem as well: If I have my phone off for more than a few minutes, the screen is mostly unresponsive unless I sleep and wake. It will respond to some touches but not most, and it’s bad enough that I can’t even swipe to unlock. I have not replaced the screen on my phone. Rather this issue started randomly one morning after sleeping on it. My headphone was pressing into the screen. A hard reboot didn’t fix anything.
I also thought it might be something to do with capacitance, like sleeping and waking was discharging something. However I bet it is a faulty connection corrupting some controller, and sleeping resets it. If opening it up and wiggling around the connection works, I’ll post here.
Puan 0
1 Yorum:
Opened up my phone to replace the battery, which required disconnecting the screen entirely. It now works perfectly! I'm guessing the digitizer connector was loose. You can follow the steps from the ifixit guide for replacing the battery on an iphone 5s.
tarafından
Yorum Ekle
Thanks for the good ideas to bring it. I know a lot more. :)
[url=http://www.ufa007.com][color=#e1e1e1][size=1px] พนันบอลออนไลน์[/size][/color][/url]  :J
Puan 0
Yorum Ekle
Yanıtını ekle
jolson1129 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 41
Her zaman: 3,841
