Ana içeriğe geç
Latest vacuum sealer from FoodSaver, released late 2015. Contains an accessory hose, PulseVac button, and multiple settings based on food consistency.
8 Soru Tümünü görüntüle
How do I remove the dip tray?
The dip tray is full. How do I remove it?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
As shown on our troubleshooting page, on the bottom front edge of the machine, pull on the handle to pull out the dip tray. Then, you will see where the liquid is stored. Carefully take out the tray and rinse it. Before putting it back into place, ensure that it is completely dry. Your FoodSaver should now vacuum the air out of a bag.
Bu yanıt yardımcı oldu mu?
Puan 0
5 Yorum:
How do you take out the tray. It doesn't lift out,
tarafından
Same here! They must have forgot to put the "gray release buttons "on
tarafından
Same problem! Anybody find a way to clean the tray?
tarafından
Same problem!! Can't find any info on the internet
Nov 20, 2023 by tcruz
tarafından
I had the same problem with my V5860 - then I found 2 levers on the underside of the machine which had to be pressed in while pulling on the tray.
By doing that, the tray slid out.
Good luck!
tarafından
Yorum Ekle
Yanıtını ekle
Matt Ryan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 43
Her zaman: 8,401
