Ana içeriğe geç
Touch and power button issues
Having some weird problems after replacing the screen on this iPhone. To start the screen did not work at all when I received the phone. During the repair I tore the cable that the home button connects to. I replaced that cable and now after replacing the screen the touch almost never works. I can try to swipe over to the unlock screen but it will only swipe over once or twice every 30 attempts. Also the power button sometimes just doesn't work at all and sometimes it works fine. Currently I'm going over the mother board looking for any damages but so far I have nothing. Anyone have issues like this before or know of a solution? I tried a completely different screen and the same problems are happening.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The touch problem sounds a lot like a common problem in the iPhone 6 (plus), where the touch IC no longer makes proper contact.
Unfortunately the only permanent fix is to resolder the entire thing, which requires quite some expert skills.
It's kind of hard to find decent info on this problem, since Apple won't acknowledge it.
For more information on what exactly causes it and how to fix it: http://mendonipadrehab.com/entries/gener...
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Definitely a good read. Thanks for posting that link
tarafından
Thank you so much for your help time to test my soldering skills
tarafından
Yorum Ekle
En Yararlı Yanıt
Clean the digitizer and lcd sockets with 90% isopropyl alcohol. Make sure you've secured your connections and make sure you're using quality parts
iPhone 6 Plus Screen Replacement
I would also check and see if the phones been water damaged. That would also be a 90% isopropyl alcohol clean. As for the power button. Try to clean it, you may need to get another flex cable
iPhone 6 Plus Home Button Link Cable
iPhone 6 Plus Power Button Replacement
Replace a screen compatible with iPhone 6 Plus. Includes all of the small parts preinstalled in the assembly. Features a 5.5 inch 1080 x 1920 pixel IPS LCD Display, Front Glass Digitizer Panel, Front Camera Assembly, Earpiece Speaker, Home Button Link Cable, and LCD Shield Plate. Görseli
Ürün
$49.99
Replace the cable that connects the home button assembly to the logic board compatible with the iPhone 6 Plus. This cable follows a channel in the LCD shield plate. Part #821-2658. Görseli
Ürün
$14.99
iPhone 6 Plus Screen Görseli
Kılavuz
Zorluk:
Orta
1 - 2 hours
iPhone 6 Plus Power Button Görseli
Kılavuz
Zorluk:
Zor
45 minutes - 2 hours
Puan 3
2 Yorum:
Power button is working fine after giving the it a good cleaning
tarafından
Oh, good! Glad you got it sorted
tarafından
Yorum Ekle
Yanıtını ekle
Jeremy Byers sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 2,367
