Ana içeriğe geç
The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
Adhesive issues , so very different
Hello
So i repair many Sony phones that are mainly based on glue, and even tho i have the correct adhesive strip for the job, it seems the 30% of the phones repaired, the adhesive will not stick the LCD/digitizer properly to the front of the device.
i apply heat after placing the lcd/digitizer on and i use small "clamps" to keep it all in place.
Tips and tricks boys?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
What type of adhesive are you using? How do you apply the adhesive? What sort of material are you gluing together? Glass on Metal; Metal on Plastic; or Glass on Plastic?
For many different material I prefer two part epoxy which if you have clamps or something you can use to hold the two different materials together you can wait for the two part epoxy to dry. But if I do not have the time to hold the two materials together or the materials are hard to get to stick together I use Superglue specifically one with a brush applicator which is easier to make sure the glue is applied evenly.
If it is for a material that has high heat and has a constant pressure already holding the materials together like a Gasket joint I use RTV which will create a water proof seal and resist high heat. RTV is also good for keeping electronic wiring together "close" but separate for to maintain a plastic covering. You can also use a glue gun for this also but RTV has the High Heat protection that some circuits need.
I do not know if this answers any of your questions, but I hope it helps someone.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Melvin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 143
