iPhone not powering on
After reballing baceband ic my iphone can't turn on. I think that some component must de-aligned near the baseband and also it seems like there isn't C33 component on the board. Is it possible this to cause the problem and if yes where i can get it from?
Bu iyi bir soru mu?
19 Yorum
@toastedc0re post a couple of pictures of your board and your repiar with your question. Use this guide Adding images to an existing question for that. It will allow us to see what you see. Also, how did you reball the IC?
oldturkey03 tarafından
@oldturkey03 Added an image. Inform me if you want another one, and thanks for your help!
georgekarapi tarafından
Can you please inform why you reballed it in the first place?
packinit tarafından
@toastedc0re thank you for the image. Any chance you can post one that has a bit less motion artifact? That would make it easier to identify the components
Rep: 31
@packinit I tried to reball it with flux and a heatgun as the modem number was blank and imei didn't appear. I had tried before all the "solutions" that i found on the net.
14 tane daha yorum göster
