Ana içeriğe geç
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Soru Tümünü görüntüle
Soru Kapandı
Turns on when plugged in, but it takes 10 mins?
It takes ten minutes to turn on, but works fine after it finally boots. I can't shut the screen or I have to do a hard reboot again.
Any ideas?
I tried installing a new hard drive, didn't help at all. I've completely erased everything and reinstalled Mac OS X, didn't help.
Any other ideas?
Bu iyi bir soru mu?
Puan 0
4 Yorum
Gee, when you change the question instead of updating it, it sure makes my answer look stupid.
tarafından
How long does it take to boot up from the system installation disk? Do you have the new drive in now? Did you do a clean install or clone it?
tarafından
Sorry, this is my first question.
It takes about the same amount of time to boot from the installation disk. I took the new drive out. I did a clean install.
tarafından
Ok, I have reset the System Management Unit and the PRAM, still no change.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds like your hard drive is failing. I would back up my user data ASAP. Start looking for a replacement drive. It uses a 2.5 SATA drive. Here are just some of the drives your Book will take: http://www.ifixit.com/Mac-Parts/MacBook-...
Installation is very easy: MacBook Core 2 Duo Hard Drive Replacement
UPDATE: This is an unusual problem and may take some trial and error. First reset the System Management Unit by removing the battery and unplugging the AC. Now hold the start button down for 15 seconds. Replace AC cord and battery and restart.
Next reset the PRAM: start up holding down the Option & Command and P and R keys, wait for it to tones three times.
{Please let us know the results. Thanks for working with me.
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
Agreed +
tarafından
How much free space do you have on your hard drive? Please look under the Apple to"about this Mac", more info and see how much RAM your Book says you have. Thanks
tarafından
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 925
