Ana içeriğe geç
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
220 Soru Tümünü görüntüle
iPad mini 2 display not working correctly
The display on my iPad mini 2 appears to be broken, however the glass itself is not. My son dropped it and it has done this ever since.
Pic of screen
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Hey Joey,
Do you mean yoou think the LCD or the screen.?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Yep, the LCD is definitely broken. Use this guide to replace it:
iPad Mini 2 Wi-Fi LCD Replacement
And use this part:
iPad mini 2/3 LCD
iPad mini 2/3 LCD Görseli
Ürün
iPad mini 2/3 LCD
$99.99
Bu yanıt yardımcı oldu mu?
Puan 3
5 Yorum:
Would you think it would be a good idea to buy a spare iPad mini 2 Digitizer just in case the glass cracks upon lifting the glass?
tarafından
Try to removing the digitizer first and if it gets damaged then order a new one. Just follow the instructions, go slow, watch for cables, and use heat.
tarafından
Would it be possible to replace the LCD with a non retina model to cut cost?
tarafından
I don't think so, the cable is probably different.
tarafından
Won't work. You will run into issues where the LCD won't display.
tarafından
Yorum Ekle
Yes the LCD is definitely damaged. If you are careful and use plenty of heat, no need to but a digitizer, you can reuse the original, but you'll be messing with applying adhesive and spend a lot of time cleaning all your fingerprints off of the underside glass of the digitizer. To save yourself time and energy, get a new digitizer with IC chip. You will be glad you did when your finished. Reusing the glass is fine, it will require a lot more prep time (A LOT) to make it look like new.
Puan 1
2 Yorum:
So you're saying replace the LCD and digitizer?
tarafından
Replacing the digitizer is not necessary.
tarafından
Yorum Ekle
It's not necessary, but will be a huge time saver if you want the finished product to look like new
Puan 0
Yorum Ekle
Yanıtını ekle
Joey sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 151
