Ana içeriğe geç
Model numarası RCT6773W22 olan, 2014 yılında piyasaya sürülen 7 inçlik RCA tablet için cihaz onarımı ve sorun giderme.
Green Border around Screen
My RCA tablet has a green dash border around the edge of my screen. I have tried turning it off and a reset but still the border and the device will not work. When touched the border will move to a box or rectangle around the area touched. Pls help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
4 Yorum
can you post pictures of what exactly is happening? this is a strange issue, never heard of it before. If you are getting a red border, resetting the settings in developer options will fix that.
tarafından Paylaş
My son has this issue . What soes it mean??? Help
tarafından Paylaş
post pictures of the issue
tarafından Paylaş
How do i get rid of that green border around my fire tablet i can't get in to anything
tarafından Paylaş
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I had this problem too, you have to hold the icon that you need to use until the green box pops up, and then double tap, once you have it unlocked, do the same thing (hold down and double tap) to settings, and turn off talk back (you might need to search it once your in settings, like I did) and then your tablet should be fine after that.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
I am having trouble now I am stuck in my camera
tarafından Paylaş
Yorum Ekle
How do i get this green box from my RCA tablet
Puan 0
Yorum Ekle
I would check if you accidentally turned on show screen changes in a developer mode. if not it could be a small internal crack in the lcd. UPDATE: re reading it you have an assistive touch on. look in your settings and accessibility settings and make sure everything is turned off
Puan 0
Yorum Ekle
Yanıtını ekle
Liam Boland sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 4,871
