Ana içeriğe geç
USB flash sürücüler (jump drive, USB bellek veya parmak sürücü olarak da bilinir) için onarım rehberleri ve destek.
Recover lost data fromBroken Usb
I had the Usb plugged in to my laptop well I was at my desk while I was going to take it to another room because my brother asked for help I dropped my laptop and the Usb hit the side of the table, and broke. How do I fix it or how do I recover the 7 years of data stored in it?
Bu iyi bir soru mu?
Puan 1
1 Yorum
Is the USB port snapped off, or is it just bent? Please post a picture.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you're lucky, it's just the connector that is damaged. This is a straightforward repair if you have good soldering skills or you can have it done by a micro-solderer. Sometimes however, the damage is more on the controller/NAND side of things. You may have cracked pads or traces or even cracked solder balls if the NAND is mounted in a BGA package. This is a more serious repair and best left to an experienced micro-solderer.
Finally, you may have physically damage the circuit board to the point where the only way to get the data is via transplant (requires an identical board, not just the outer housing and model number) or chip-off data recovery. You can't just wing it as mixing the wrong controller with the NAND can scramble the data forever. This is best left to professionals.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
AlikeSpy 29942 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 817
