My mobile is alcatel onetouch locked
its locked and require username and password but i forgot it
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi! I am assuming you have forgotten a Username and Password required to open the phone. If this is the case, you will need to reset the phone.
To reset the phone:
With the phone turned off, press and hold the Volume up and Power button for a few seconds until you see the reset interface.
Select Wipe data/Factory reset using the Volume buttons. Press the Home button to confirm.
Select Yes - Delete all user data and press Home button to confirm again.
Select Reboot system now, and then press the Home button.
The reset will now be complete.
Bu yanıt yardımcı oldu mu?
Hi @ berthaguerra041
Short answer is yes.
If you hard reset using the hardware keys (or factory restore from the Settings menu) then all your data and downloaded apps will be erased.
If you can still access into the phone, backup the phone to the cloud or a computer before performing a reset by using the phone’s backup feature (see Settings menu)
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,335
3 Yorum
I did these steps and it says no command what do I do now
el chingon tarafından
Will I lose my data if I reset the Alcatel one touch
berthaguerra041 tarafından
Lost all my data in the hope I'd reset my phone bk to new gig ripped off
Albert tarafından
