Ana içeriğe geç
OnePlus' second entry into the Android phone market, the OnePlus 2, was released on August 11th 2015.
49 Soru Tümünü görüntüle
!HELP! Bootloop because of low battery ONEPLUS TWO
Hi
My OnePlus Two turned off because the battery was low, however after it turned of the phone got in a bootloop but fails to start since the battery is dead... the phone also doesn't seem to charge... any idea on how i can make the phone stop bootlooping and just stay off so that i can charge it properly?
I've already disconnected and reconnected the battery from the motherboard but is soon as i reconnect it starts bootlooping again
Thanks for the help!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
I had an similar battery issue when I owned a Motorola Defy and I used a tutorial I found on XDA Developers to charge my battery. I would expect similar results to help charge your battery. If the bootloop is a result of the battery being low, then this may help, but if the bootloop problem remains, there may be something else going on.
Hopefully, this does work for the battery.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Lennert sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 865
