Why my phone is not switched on
dear sir,
my phone is switched on but it is strucked on the page as lava android it does not get in. its my problem
Bu iyi bir soru mu?
dear sir,
Bu iyi bir soru mu?
Hi,
Try a hard reset.
Be aware that a hard reset will erase all your user data and downloaded apps. It will restore the phone to a factory default condition. It will be like when you first bought it.
Ensure that the battery is fully charged before you perform a hard reset. Do not leave the charger plugged in when you perform a hard reset.
Be patient, the reset takes a little time to complete.
Here is the procedure.
Turn off the device then:
Press and hold Volume Down key + Power Key for a while ( about 10 seconds )
Release all the keys when you see Lava logo
Press and hold Volume Down key until you see Factory reset menu
Press and release Power key to enter Recovery Mode
Use Volume key to select Menu
Use Power key to Confirm or Execute Menu
In Recovery Mode select wipe data / factory reset
press Power key to confirm
select Yes — delete all user data, press power key to confirm
select Reboot system now to finish hard reset.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 4
Son 7 gün: 19
Son 30 gün: 45
Her zaman: 4,781
when i try to install an custom rom in my lava 2x ,i download a twrp flash file and install it first it say reboot so i reboot it but it show only lava logo and long vibration what can i do now..pls help me..
sugan sugu tarafından
it's coming
please this problem
Tharun Adn tarafından
Dear friend my phone lava iris51 is not starting please tell me how to fix my phone
SK᭄രാക്ഷസൻ࿐❷ FF PLAYER tarafından
