Ana içeriğe geç
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Soru Tümünü görüntüle
Can I put an iPhone SE into a 5c case?
Can I put an iPhone SE into a 5c case? Love the pink 5c so much, but so much wanted it works like a SE with powerful A9 and 12-mp camera.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If you are talking about cases you put over your phone: No, the 5c is slightly bigger. The 5, 5s, and 5se cases are interchangeable though.
If you are talking about the chassis/frame that you screw the logic board and other components on: No, each iphone model uses a unique chassis/frame.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Well yes, but actually no.
I managed to do it. But it needs a lot of time, glue and knowledge. It does not work a 100%, things like the Vibration motor does not fit in anymore and smaller imperfections like the camera not aligning are there. But overall it is manageable.
I have a picture of it on Reddit:
https://www.reddit.com/r/iphone/comments...
Puan 1
Yorum Ekle
No, this will not work. Whilst the 5C is 24.4 x 59.2 x 8.97mm and weighs 132g, the SE measures 123.8 x 58.6 x 7.6mm and hits the scales at 113g. This means that the iPhone SE is slimmer and smaller than the iPhone 5C. Furthermore, the mouting points for parts and screws are also different.
If you really want the SE to look like a 5c you could look around for a case online.
Puan 0
Yorum Ekle
no you cant because they different phone
Puan 0
Yorum Ekle
There are housings out there with different colours etc. You can make your iPhone 5 look like a small iPhone 6S. However, nobody has made a housing to fit an SE to a 5C because it's considered a downgrade.
Your best option is finding some pink housings that are made for the SE:
http://www.aliexpress.com/wholesale?catI...
Puan 0
Yorum Ekle
Yanıtını ekle
Dax Liu sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 15
Her zaman: 4,821
