bottom charge / pulse sensor
My aplle watch bottom cover came off with the charger and the ribbon cable is broken. The two small cables for charging are still intact and I can still charge the watch but the pulse sensor is not working. where I can buy replacement sensor?
Thank you in advance
Update (09/10/2016)
Yes I saw that section but there is no sensor there. I know it is a common issue that the back of the watch is falling while detaching the charger and I was curious why there are no replacement parts for this issue. And the replacemet is prety simple. there is only one ribbon cable with connector and two tiny wires that have to be soldered for the charging and that is it. This is the needed part.
Bu iyi bir soru mu?
