Ana içeriğe geç
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
iPod Touch 5th Generation
So the problem with my iPod is that it won't charge like for example ur battery is at 20% it would stay there it won't charge at all I don't know if it is my charger or its my iPod
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Without knowing more details about your ipod (if you dropped it, spilled water on it, bent the charging port etc), these are my suggestions:
The first thing to try would be a different charger and a different outlet, to ensure that those are not the culprits.
Batteries do have a limited life span; after a certain number of charges (~2000) they will start to fail until they eventually can't hold a charge anymore. You could be due for a battery replacement. This guide, up through step 16, outlines how to do this.
iPod Touch 5th Generation Logic Board Assembly Replacement
You could also have an issue with the charging port, a replacement is outlined here, through step 27.
iPod Touch 5th Generation Rear Case Replacement
Good luck!
iPod Touch 5th Generation Logic Board Assembly Görseli
Kılavuz
Zorluk:
Zor
1 - 3 hours
iPod Touch 5th Generation Rear Case Görseli
Kılavuz
Zorluk:
Zor
Bu yanıt yardımcı oldu mu?
Puan 5
1 Yorum:
Great answer! You need some more rep!
tarafından
Yorum Ekle
I think you should check your charger on another apple device to see if it charges that and if it doesn't its not your ipod its your charger
Puan 0
1 Yorum:
This has already been resolved and accepted.
tarafından
Yorum Ekle
Yanıtını ekle
Zubair sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 187
