Ana içeriğe geç
Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
20 Soru Tümünü görüntüle
About Memory slots on Mac mini
What happen if the memory removed many time from memory slots many times may happen erosion in the lips that found in the middle of slot "and i mean erosion , the picture clear my mean" and the first remove to the memory i found a simple erosion as the picture clear and i remove the memory in the correct way so it an normal or not
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Most of your internal connectors are not designed to withstand constant disconnect/reconnections, that includes the RAM slots.
I would say more than 8 times is about the breakpoint. Why are you swapping in and out the RAM so many times?
Update (09/22/2016)
The image looks just fine! The slot pin is not designed to be bottomed out with the module if that was your concern. Here's an image from the IFIXIT teardown: Memory modules seated correctly in the slot so you can see its the same.
Lets backup here ...
Forget about the RAM for now. What is happening with your system is it working or not? If not explain what you are seeing as best as you can. Did you replace something? Did you smell, hear or see something?
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Everything is good i just asking about this point and i didn't smell anything and i didn't hearing anything and i had made Apple Hardware test and the result was " no trouble found "
tarafından
Thats great! You had me worried ;-}
tarafından
Yorum Ekle
Yanıtını ekle
mohamedhaitham36 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 425
