Not firing when trying to crank
My power washer does fire when I try and crank it
Bu iyi bir soru mu?
Bu iyi bir soru mu?
gail, trouble shooting pressure washer small engine will not fire. You will have to test the engine for fuel/air/spark/compression and see what is missing/faulty. Check the attached links,instruction and guides, Good luck
http://www.repairfaq.org/samnew/lmfaq/lm...
https://www.briggsandstratton.com/na/en_...
http://www.jackssmallengines.com/diy/tro...
Bu yanıt yardımcı oldu mu?
Check Sparkplugs for loose wire, dirty connection, or debris. Spark plugs on small equipment can also break pretty easily since they are exposed.
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 399
1 Yorum
gailfeltman what make and model is it? What do you mean by "washer does fire when I try and crank it"? It fires up? It comes on fire?
oldturkey03 tarafından
