Ana içeriğe geç
Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
Fusion drive delete and configure 2x ssd in raid 0
i bought a macmini 6,1 late 2012 today.
It has 1 tb fusion drive and it works well but not what I expected as I planned to use a data doubler and plunk in 2 x 960 gb sata 3 ssd in raid 0.
Internet searches have me confused that the connectors are different with fusion drive installed.
Can I still go ahead with my project with just a data doubler and add 2 2.5"size ssd?
Bu iyi bir soru mu?
Puan 0
1 Yorum
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes! Your system can support two SATA HD or SSD drives!
Here is the kit you need: Mac Mini Dual Drive Kit which gets you the needed parts and tools to put in the second drive. And here is the IFIXIT guide you'll need to follow: Installing Mac Mini Late 2012 Dual Hard Drive Kit.
Are you sure you got the Macmini6,1? I suspect you got the Macmini6,2 Mac mini 2.3 GHz i7 (Late 2012) as it was the first Mac mini model which offered a Fusion Drive. In this series Apple used a 2.5" SSD.
If you got a newer 2014 then you'll have issues as it can't support two SATA drives. Instead it supports one SATA drive and one PCIe custom Apple blade drive. Here's the IFIXIT guides for this series: Mac Mini Late 2014.
If you review this Mac Mini Late 2014 Teardown jump to Step 5 while not present in this system the area just behind the fan is were the Blade SSD would be which you can see in Step9. In the 2012 models this would be a 2.5" HD or SSD. You may want to pop the bottom off to double check what you really have here.
Its also possible someone created their own Fusion Drive setup as well.
All the hardware needed to a second hard drive to your 2011 or 2012 Mac mini. Görseli
Ürün
Mac mini Dual Drive Kit
$26.99
Mac Mini Late 2012 Dual Hard Drive Kit Görseli
Kılavuz
Zorluk:
Orta
1 - 2 hours
Mac mini Late 2014 Görseli
Kılavuz
Mac mini Late 2014 Teardown
Zorluk:
Orta
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Before you take any drive out you'll want to break the Fusion drive set first!
Follow the steps outlined here: How to split up a Fusion Drive
tarafından
Yorum Ekle
Yanıtını ekle
Kevin Brown sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 618
