Ana içeriğe geç
Released in June 2014, this touch 2-in-1 laptop gives its users a reliable computer at a low cost. This device has similar problems to previous models, so detecting problems and finding solutions should be painless.
Why is my laptop overheating?
After a short period of using my laptop, it gets really hot and eventually turns off by itself. What can be the reason this is happening?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Have you cleaned out the laptops fans? Dust can accumulate inside the laptop, causing overheating. Open up the laptop and clean it out with a cloth and can of compressed air. After that, remove the heatsinks (The thing with copper tubing). Then clean off the CPU and GPU with Isopropyl alcohol. After that, apply some new thermal compound (Arctic silver 5 is highly recommended). Forgot something, clean the heatsink too. Same steps as CPU and GPU. Except don't reapply thermal compound. It's already on the CPU and GPU, If you reapplied it. Now just put everything back together! It should work fine. If it is your first time doing this; take pictures as you go along the way. It will help you put it back together. If you need more help, feel free to ask me. Keep this in mind: There is nothing wrong with a good google search. If this helped; let me know by Upvoting this.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Hi @tharickm
Can you hear the fans running? Are the cooling vents clogged with accumulated dust?
To help you with Eddie Dehoyos answer, here is a link to the service manual for your laptop. This shows the procedure on how to open and remove components from the laptop. http://www.manualguru.com/hp/pavilion-11...
tarafından
Yorum Ekle
A simple solution to this would be to open up your device and use a compressed air can to spray out the fans for potential dust. If this solution does not work you may need to replace the heatsink to the processor. For a link to the troubleshooting guide on this device click here.
Puan 0
Yorum Ekle
Yanıtını ekle
Tharick Moulton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 268
