Why can’t my tablet connect to WIFI?
I can not get my tablet to connect to the WIFI
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi @Michael Emery,
Can you access the network when the tablet is right next to the router?
If so try disabling the tablet’s WiFi’s minimum power consumption setting. Go to Device Manager > Network Adapters > right click Broadcom Wireless > Properties > Advanced > minimum power consumption and see if that helps. (not quite sure if it is called minimum power or something similar)
Bu yanıt yardımcı oldu mu?
Make sure the WIFI is enabled. If this does not work perform a hard reset. If the problem still persists check your router or modem to see that they are properly connected.
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 299
It not the network as i have reset it and all other devices have picked up the network
Michael Emery tarafından
