Ana içeriğe geç
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 Soru Tümünü görüntüle
Dead spot in new digitizer. Replaced twice. Dead spots.
Customer brought in an iPad Pro 12.9" with a cracked screen. I replace the screen and soldered the new one on properly 100%. Customer has issues with the dead spot on the screen. So I ordered a brand-new digitizer assembly and install that one. Exact same issue as the first one. Anybody have any suggestions? No apparent damage to the control board and soldering is good. Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Same supplier? Seconds?
tarafından
Different Supplier. LCD is good on both.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
then the controller board is bad, simple
Update (11/11/2016)
sounds to me like proccess of elimination its the controller board, too much heat, etc can damage a controller board, hope you find a solution.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
lcd is not ok failure
Puan -2
1 Yorum:
LCD is perfectly fine on both. Ordered from 2 separate manufacturers, dead spot in same exact area.
tarafından
Yorum Ekle
Yanıtını ekle
GadgetERService sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 479
