Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
Charging iPhone 4s problem?
My iphone 4s will only charge sometimes. I have to plug it in and out a bunch of times until it finally charges.
but when my phone shuts down and I plug it in once it will charge until it turns on and then the battery is not charging at all once the lock screen loads up?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you haven't already, firstly try another charging cable and / or wall adapter.
Those are all signs of a bad charging port. Replacing it should do the trick.
Where you can buy the part:
iPhone 4S Dock Connector
Guide to replace the part:
iPhone 4S Dock Connector Replacement
Replace a dirty, damaged, or corroded dock connector to fix problems with charging, connectivity, and USB recognition. Görseli
Ürün
$19.99
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
if you're able to check the voltage of the battery would be helpful to know also. It could be the battery either needs a boost or is defective.
Puan 0
Yorum Ekle
Yanıtını ekle
Steph sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 138
