Fuel pump needs replacing.
My car is running but hesitates when I give it gas, then it surges. I believe it is the fuel pump. Would like to do it myself. Is it really difficult?
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
Bu yanıt yardımcı oldu mu?
Disconnecting the car battery before replacing the fuel pump is also a good idea.
Check EGR and gas filter
Did the replacing the fuel pump work?
So i have a 01 honda crv… when i turn car on it idels crazy. Then sometimes my rpm gage will work sometimes not. It stoped working when i tried to give my car gas. It was stuffering like it was trying to shut off as i was going down road. Sometimes it will die when i come to a stop. I gave to put it in neutral and keep foot on gas. Then there are days she runs great . Put in new filter. And a idle air control sensor. And its still doing it. It didnt start this until i got timming belt done. The shop has looked at it and its not because of the timming .. so please help what could it
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,776
1 Yorum
I would check for vacuum leaks before condemning the fuel pump.
Travis tarafından
