Ana içeriğe geç
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Soru Tümünü görüntüle
My screen has a speck on it?!?
So I generally keep my MacBook in very good shape, but the other day I noticed a little speck in the middle of the display. I ran my fingers gently over it and felt something (so it's not a drop of water or something). Between the keyboard and palm rest I also found a little piece of something, which I scraped off (this is approximately the same position as the speck on the screen). I don't want to scratch at my displya trying to get something off, for fear of damaging it. Is there some way that I can:
A) Determine whether I can safely "remove" this speck, and
B) If it is an indentation or other mark on my display, can I fix it without replacing the whole display?
All help is appreciated, and thanks in advance!
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Spray a little Windex on a very soft cloth and see if it will dissolve.
Update: If the speck bothers you that much, here's the guide for replacing the screen: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
Bu yanıt yardımcı oldu mu?
Puan 3
9 Yorum:
Thanks for the suggestion Mayer, however this did not resolve my problem (although I haven't cleaned my screen properly in a while, so it did make the screen cleaner overall). After a few minutes of rubbing at the spot, it is still there. Any other ideas? I think I remember hearing that Vaseline could be used to fill in nicks in this type of display, although I can't verify that it's a good idea or not.
tarafından
I really wouldn't put something like vaseline on my screen as it would attract dirt. Try using a magnifying glass to see what it is.
tarafından
It looks like it's a small indentation. It's darkening the pixels in about a 3x3 range, which makes it quite visible whenever I work. Any ideas?
tarafından
Look on the keyboard to what's sticking up to high and causing the indentation.
tarafından
There was a piece of something there before, I scraped it off already.
tarafından
4 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Adam Hintz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 2,087
