Ana içeriğe geç
Linksys EA9200, 3,2 Gbps'ye kadar kablosuz hız sağlama kapasitesine sahip üç bantlı bir yönlendiricidir. Tüm ağ etkinliklerini ve taleplerini hızlı bir şekilde işlemek için 1 GHz işlemciye sahiptir. 4 adet Gigabit ethernet bağlantı noktası ve 2 adet USB bağlantı noktası (biri USB 3.0) bulunur. Akıllı cihazlar için Linksys Smart WIFI Uygulaması ile uyumludur. 5 GHz bandında yüksek veri trafiğinde, 2,4 GHz bandında ise daha düşük trafikte çalışır.
One external broken antenna
When I was setting up the device one of my antenna broke, Is it possible that the router works like that, or do I need to replace the antenna?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Where exactly is it broken?
Has the connector port on the top of the router been broken or just the antenna itself?
If it is the port connector then there may possibly be more damage inside the unit.
If it is just the antenna that has broken and not the connector port, then it depends on which antenna has been affected. I think that there is 1 antenna for the 2.4GHz band and 2 antennae for the 5GHZ band, but I do not know which is which. You will most probably experience connection problems, drop outs, reduced range etc. It may be best to contact Linksys support to get information regarding which antenna has been affected and whether replacements are available. Here is a link http://www.linksys.com/us/support-articl...
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
It looks like 2 of your antennas are for the 5 GHz operation and the other for standard 2.4 GHz. So depending of which one is broken the router should function normally. If this is a office setting with multiple floors and you are actually using the 5G quite a bit you may experience a smaller coverage area. The 5G will penetrate thicker walls but not go quite as far as the 2G .
Puan 1
Yorum Ekle
Upgradeable antennas mean you may not have to buy a whole new box to get better Wi-Fi. The antennas should deliver a significant bump in horizontal range, but if you’re having difficulty reaching a wireless client (a smart TV, a streaming box, a laptop, or what have you) on a floor above or below the router, you’d be better off with a power-line range extender or stringing ethernet to a wired access point.If you need right help then connect linksys team by clicking http://www.linksysroutersupport247.com/
Puan 0
Yorum Ekle
Yanıtını ekle
wendy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 10,419
