Ana içeriğe geç
Repair guides and support for your Samsung TV.
The red button facility no longer works
When I press the red button, a window appears with this message: "Your TV needs an update to access this BBC service. Update your TV Apps through your App portal or store (and TV firmware if required)" There is then a yellow button saying MENU.
When I press the yellow button, the TV returns to the original channel it was on before trying to press the red button, and it is not possible to change channels without turning the TV off and then on again.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Hi, What is the model number of your TV?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Get your Model # off of the back of your computer and then get a 4Gig USB Drive and go to Samsung's webpage and download the updated firmware to that thumb-drive and open the file(UNZIP) on that drive making sure it is opened on the root level of the thumb-drive. Plug the thumb-drive into the maintenance USB port of your TV. Then load the new firmware using the firmware upgrade in your menu settings of your TV's menu system. Wait until the upgrade is complete. (Do Not turn off the TV during this otherwise you could permanently break your TV. )
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Anne Hebden sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,140
