Ana içeriğe geç
The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
Why does it keep going into safe mode
Safe mode:
Sometimes when I turn my phone back on it is in safe mode. ..why or what is causing this to happen
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
1 Yorum
My phone is on safe mode and it is locked, when I input my number pin is say try agine in 2 minutes or more
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
My phone suddenly and without being g touched , went into “safe mode” and “airplane mode” was activated as well. I would like to know how this could possibly happen. In addition, all my app icons are greyed out, with the exception of any GOOGLE APPS.
thank you
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
What i doing wrong
tarafından
Yorum Ekle
The Galaxy Note 2 Safe Mode works much like that with Windows-based computers. It only loads the stock apps or the basic programs that the device needs in booting up successfully.
Entering the Galaxy Note 2 Safe Mode is a basic troubleshooting method that will enable you to detect if one or more apps that you have installed are causing the errors that you are experiencing with your Android phone.
The reason why it's booting up in safe mode sometimes is because you're accidentally executing it's button combination when you turn on your phone! Below ate the instructions on how you enable or disable this mode when turning your phone on for your future reference.
''Enabling the Samsung Galaxy Note 2 Safe mode:
1. Turn off the Galaxy Note 2 by pressing the Power button (positioned in the right edge of the device). Tap Power Off from the choices that will appear followed by OK.
2. Once the device successfully shuts down, press the Power button again, but this time, keep your finger pressed on it together with the Volume Down button.
3. Let go of the Power button when you see the Samsung Galaxy Note II logo but do not let go of the Volume Down key yet.
4. After that, you will see a status message telling you that your Galaxy Note 2 is now in Safe Mode. Let go of the Volume Down key and tap the OK button.
Disabling the Galaxy Note 2 Safe Mode
To exit the Galaxy Note 2 Safe Mode, all you have to do is turn off your phone normally using step 1 above. Then, power it on using the usual way.
Hope this helps you understand what's going on & why! If this helped you out, feel free to express this by "accepting" my solution as your chosen answer!
Cheers
Puan 0
Yorum Ekle
Why and how do I fix it
Puan 0
2 Yorum:
Please help me fix my phone because every time it goes in to safe mode my phone wont let me listen to music and my media won't work it turns it down
tarafından
As I mentioned in my previous response above, the reason its starting up in that mode is because you're most likely triggering it to start in "Safe Mode" by executing the button combo accidentally & are simply not aware you're doing so until you see that "Safe Mode" msg on the bottom of your phone's display!
It certainly shouldn't be starting up in safe mode like that each time you turn the phone on... it should only do that if you're executing the relevant button combo while the phone is starting up. If it's starting in safe mode like that every time you turn it on then it maybe indications of a hardware or software issue possibly.
That being said, only thing I can really suggest to you is that if you do happen to notice that it started up in safe mode again, just do a normal reboot (Hold the power button and click "Restart Phone" & it should reboot normally and that pesky "safe mode" msg should be gone!
tarafından
Yorum Ekle
What is safe mode keep coming on how do I keep it from doing so
Puan 0
Yorum Ekle
Your phone is always going into safe mode because you may have a virus on your phone. try to backup your data on your laptop or pc and do a factory data reset.
Puan 0
Yorum Ekle
wtf virus can boot always to safe mode ;D? never heard
Puan 0
Yorum Ekle
Yanıtını ekle
Jessica Fitzgerald sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 12,345
