Ana içeriğe geç
Sony tarafından 2012 yılında tasarlanan ve üretilen dijital bir fotoğraf makinesi. Wi-Fi, GPS ve hafıza kartı yuvasına sahip 18,2 megapiksellik bir fotoğraf makinesi.
Program Selection Wheel not working properly
Hi,
hope you can help: when I select a program it is often lost. For example: I set the wheel on P but on the screen the selection is - M. I have to move the wheel just a little bit to have the right program set again, but sometimes it's immediately lost again.
Maybe dust under the wheel? How can I clean it?
Thanks,
David
Bu iyi bir soru mu?
Puan 1
2 Yorum
Now the wheel works (even if ha become a little bit harder to roll), thanks!
Davide
tarafından
David, Glad to here it is working, pretty sure it will start easing up with usage after the cleaning. have a good day.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@catchtherainbow , David, Sony Cyber Shot, remove the battery, squirt a (little) 90% Isopropyl Alcohol under selection wheel and blow out/dry with canned compressed air. Repeat a couple time and this should clean out the dust/dirt from under wheel.
If this does not correct the issue button internal stops are probably worn and button assy. may need replace to correct. I will post a tear down guide if you wish to dig a little deeper into your device.
Sony Cyber-shot DSC-HX20V Dış Kasa Değişimi
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Yanıtını ekle
David sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 45
Her zaman: 1,750
