Ana içeriğe geç
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
20 Soru Tümünü görüntüle
Powers itself off after about 5 minutes.
PowerMac G5 DUal 2.0 Ghz PCI-X
Serial No. : CK411J3JQVJ
This PowerMac works perfectly... until it powers itself off.
I expect it needs a new PSU? but which one ?
Bu iyi bir soru mu?
Puan 0
1 Yorum
Seeing a kernel panic notice on screen?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Disable
Energy Saver computer sleep & put hard drive to sleep settings.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Bu yanıt yardımcı oldu mu?
Puan 2
5 Yorum:
Try this first +
tarafından
To me it sounds like overheating of either the power supply, or the CPU. I'm sorry but I can't help you with the power supply diagnosis CPU overheating could be from myriad problems, sensors, logic board, fans, old dry thermal paste.
tarafından
Thanks,
There are no Kernal Panics or such Screen output.
Nothing is logged in the system.log in Console.
The Energy / ScreenSaver settings are OK.
The power cuts out, just like the plug had been pulled, it is not a usual shutdown or timed logout sequence.
tarafından
Please post this as a Update to your Question or a comment to my Answer only Answers belong here.
tarafından
awaiting new PSU... will report back on result...
tarafından
Yorum Ekle
Yanıtını ekle
jrpsupport sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 928
