Just been in chat with a mac technician...hope this helps all. pimp my score :-)
Brandon:
I am doing well. To answer your question, unfortunately I do not have all of the part numbers that are available for the LCD. Apple uses three or four different manufacturers for the LCDs in the MacBooks, and each manufacturer has its own part number. However, they are all interchangable and compatible with each other. We cannot guarantee you will receive the same manufacturer as the one you currently have, but we can guarantee compatibility.
SIMON:
ok so do you know if the lp133wx2-tlc1 from the unibody MacBook Pro fits the MacBook a1342? its confusing as trying to find the right lcd
SIMON:
well one that will fit and work
Brandon:
From what I've been told and what I've seen, the MacBook aluminum Unibody, polycarbonate Unibody, and MacBook Pro 13" Unibody all use the same LCD.
SIMON:
ahh ok because there some confusion as there all diffrent part numbers.. mines lp133wx2-tlg1 and MacBook Pros are lp133wx2-tlc1 and the 13 ends with e1....and seen some unibody models end in tlg2. so its confused the hell out of me which one to order..lol
Brandon:
lol, yeah, what you are seeing (those last two letters and numbers changing) are usually revisions that the manufacturers (LG in particular, as the part number you are referencing is for the LG models) make to the LCD. As long as the main section of the part number stays the same, then they should be all compatible.
SIMON:
brill ok how much is shipping for one to the uk? any idea if i buy from you?
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
2 Yorum
hello everybody
The problem is that the screen it´s totally different from the MacBook unibody aluminium, because the screen looks like is one piece stick with glue or something,........ there´s no screw or frame click together.. as I said looks like it´s one piece, so I can not separate the actual LED-LCD from the frame a plastic cover of the outside.....
one more thing........ in the aluminium unibody, there´s a lot of info on how you separete the cristal front to have access to the LCD, but in this new unibody white MacBook there´s no info....... ciaooo
Thanks!
franalvarenas tarafından
Hello everybody
I just did it........ the procedure is in fact more easy than previous models because it doesnt have inverter.....
First step for safety is to remove the battery.
second following the procedure of the MacBook Pro to remove the front cristal....... heat a little bet the white front basel and slowly remove the plastic front.......
thirt remove the screw.
last now you have access to the LCD, removed the conector....
The part number is LG Philips LP133WX2 (TL)(G2)........I have been contact with a lot of providers and they run out of stock.... Does anybody knows another screen that will work with the MacBook unibody policarbonate?????.
thanks.......
