Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
2690 Soru Tümünü görüntüle
Stuck in DFU mode
son dropped his iPhone 6s, cracking the screen protector, and the screen. I just replaced the screen using the ifixit complete kit, and the original home button. Could not get the phone to power up. Downloaded newest iTunes and connected phone. iTunes believes phone is in DFU mode. Attempting to restore generates error 9. I have switched cables, and even using the Apple cable generates the same error.
During restore attempt, apple logo and progress bar appear on phone screen.
Holding power and home button then releasing and pressing power button does nothing.
Any help appreciated.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Use Reiboot it will get you out of DFU mode with a just one click Get it here
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
If this does not work OP unplug the battery and then keep the home button extension cable and front camera cable unplugged. It should still be in DFU mode when you attempt to turn it on (DFU mode is usually a black turned on screen probably it's a bit hard to tell).
Try restoring it and see if it succeeds. If it does then it's either the front camera ribbon cable is damaged or the home button extension cable / home button cable being damaged.
tarafından
Yorum Ekle
Yanıtını ekle
dhelvey sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 1,612
