Ana içeriğe geç
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
not charging... no 3.3v... power manager?
Hi guys... I', struggling trying to solve an issue with this iPad Air...this is the scenario: while off, when connectin lighting cable it switches on but it does not charge the battery... what\s weird is that there is no "not chargin" message near battery icon... simply nothing.
Analyzin with multimeter there are no shorts at all in the board, but 3.3 volts rail is completely missing..... all the other voltages are present. I tested continuity between dock pins soldered to the board and checkpoint and everything is ok... I already replaced the charging IC (U6000) but no result.... each and every smd belonging to PP3V3_ACC line is good and functional... should I replace the power manager (U8100) or anyone of you can suggest me other solutions? thanks everyone in advance....
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The PP3V3_ACC line is only present when the phone powers on. Otherwise, unless there is an accessory plugged into the Lightning port, you don't need to worry about it.
Did you check all the rails generated by the PMIC, there are a few dozen?
Perhaps your Tristar replacement did not succeed and you should try it again.
EDIT
This is the Tristar circuit. Check the following voltage rails
PP3V0_S2R_TRISTAR
PP1V8_S2R_TRISTAR
PPVBUS_PROT
(but not PP3V3_ACC)
You should be able to find the schematic on the web
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
and could you tell me what are exactly the rails to check, the ones involved in battery charging process?
tarafından
the voltage rails you mentioned are present... I thought the problem was in PP3V3_ACC just because battery is not charging.... so confused :-(
tarafından
As I said, perhaps your Tristar replacement did not succeed. You should also check all the PMIC rails, the problem could be elsewhere. Good luck!
tarafından
Yorum Ekle
Yanıtını ekle
Dolcebimbo72 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 973
