Can I use a 9mm 115 grain
Can i use a 9mm 115 grain in a 9mm ×18 makarov.
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
Again, the easy answer is NO. Your "9mm" (also known as 9mm luger or 9mm parabellum) is 19mm long and will not chamber. Additionally, even tho they are both "9mm", 9x18, also called 9mm Mak, is a larger diameter. 9x17, also known as 9mm kurz, 9mm browning, and .380acp will work in a 9x19 pistol just like .38 special in a .357 or .22lr in a .22 mag, but the smaller diameter will make it highly inaccurate in a 9mm Mak. The correct caliber should be stamped on the slide and "alternatives" are generally a bad idea.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 215
