Ana içeriğe geç
Repair guides and disassembly information for Apple's Macintosh personal computers.
42814 Soru Tümünü görüntüle
Is thermal grease/paste also electrically conductive?
Is thermal grease/paste also electrically conductive? I've seen phone line repairmen squeeze a dollop of this clear grease into a phone jack before they plug a RJ11 in and they tell me that it's an electrically-conductive grease that prevents moisture from interfering with the connection but conducts electricity fine.
Bu iyi bir soru mu?
Puan 0
2 Yorum
I worked for the phone company.... It is not electrically conductive... otherwise you'd creat a short...it is simply for protection from water and moisturizer
tarafından
Ok. That makes sense. But if that's the case, how do the metal contacts on the RJ11 connect with the pins in the jack so there's a good electrical connection with the insulated grease in the way? After all, it's not as if they are very discerning when they squeeze the dollop of grease into the jack in the wall?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
It depends on what is in the grease compound.
Here is a link to one example where it is both electrically and thermally conductive.
http://www.timtronics.com/electricallyco...,
Whereas this one is non electrically conductive but has high thermal conductivity.
https://www.amazon.com/ARCTIC-Carbon-Bas...
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
Many thanks for your answer. It answered my question completely.
tarafından
Why is the carbon based one not conductive? Carbon is very conductive.
tarafından
Hi Ryan Stone,
It may be that it is some sort of carbon "compound" which can be non conductive.
If you look up "is carbon conductive" you'll find answers that describe the conditions where it can be and then where it isn't.
So presumably they're using a form of carbon compound the properties of which are good thermal transfer and poor electrical conductivity.
They do state that it is "carbon based" not just pure carbon.
Just my opinion on this
tarafından
Yorum Ekle
Yanıtını ekle
Reality Artisans Inc sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 12,464
