Ana içeriğe geç
A Windows phone known for its camera capabilities. Also known as Nokia EOS, Nokia 909, Nokia RM-875, Nokia RM-877, Nokia RM-876.
42 Soru Tümünü görüntüle
My lumia died help me please
I have a problem in my lumia 1020. My little sister threw it in the floor and it died . It never work . I tried to turn on the phone but , I don't get a response. When I charge it light shows from the start button
And disappear after few seconds.
What do I have to do?
If I need to change components, what are their names? Can I buy them from the Internet ?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@mohannadfatani before thinking about replacing parts, you need to find out which once. There are no standard parts that fail when the phone gets dropped. Start by opening up the phone and check the battery. Check to make sure it is seated, charged and the contacts are properly aligned. If they are then you need to dig deeper. Follow this video to disassemble your phone. Check for dislodged cables, broken components, check that the power switch is okay etc. You will need to invest in a multimeter etc. to do any further testing.Take plenty of pictures of the motherboard etc. and post those with your question. That will allow us to see what you see and possibly help you figure it out. Use this guide for that.
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
I opened up the phone and checked the battery but I didn't open the battery. Should I ? If I open the battery , does this will affect on the performance ?
I returned the parts and I got the same problem .
@oldturkey03
tarafından
@mohannadfatani not sure what you mean by opening the battery. Just remove it from the phone and take a look at the contacts from the battery to the phone.
tarafından
I did what you said . Unfortunately nothing happened. @oldturkey03
tarafından
Yorum Ekle
Yanıtını ekle
Mohannad Fatani sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 264
