Ana içeriğe geç
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Soru Tümünü görüntüle
problems stays after changing dc-in
Have a macbook 1.85 GHZ intel Core 2 Duo, Battery won´t charge, no green/ red light. The macbook does take power from the outlet! I changed the DC-in board but the problem continues! Might it be the mother board?
Update
here is what coco says
Battery charge
Current charge: 961 mAh
Max charge: 3865 mAh
24% (yellow)
Battery capacity
current capacity: 3865 mAh
design capacity: 5020 mAh
76% (green)
Mac model: MacBook 2.1
Age of your mac: 48 month
Battery loadcycles: 732
Battery temperature 29.7C
Battery power usage: 0.0. Watt
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It could be you have a bad battery connector or a bad battery. You can download and use Coconut Battery to check the age, current capacity, and cycles of your battery. If the battery looks good, then I would replace the battery connector.
Update
Battery connectors can go bad over time. No real cause other than usage.
Based on the stats your battery looks fine. Have you tried using a different AC Adapter? I have run into a similar problem with my own MacBook where the MacBook will run off the AC Adapter, but will not charge the battery. I changed the AC Adapter and it fixed the problem. Also, I could fix the problem by bending the cord near the MagSafe plug certain ways. Not sure if that meant there was a short in the wires. I just got tired of having to mess with the cord to charge the battery and got a replacement AC Adapter.
MacBook Battery Connector/Sleep Sensor (non-Energy Star) Görseli
Ürün
$7.99
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
+ excellent answer
tarafından
Yorum Ekle
Test the AC adapter with a multimeter. Look at the tip and use a toothpick to move the pins in and out, (do this while unplugged).
Puan 1
Yorum Ekle
Matt, thanks for you reply, but what possibly could be wrong with the battery connector? And why the light of the mac adaptor does not show green or red?
Puan 0
Yorum Ekle
mayer, I do have a multimeter but do not understand what should be doing?
The small magnetic plug has five pins and yes I noticed that they move inside when you push...
But what should I be doing with the meter? What should each pin show?
Matt, I used another ac which did not work either so I assumed it was the dc-in board.... but after changing it the problem stayed (used my adaptor on another mac were it worked correctly)
Another strange fact is that my ethernet port does not work either (software says that there is not port present)
Puan 0
Yorum Ekle
Yanıtını ekle
willem sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 967
