Ana içeriğe geç
Sony ICFC1T alarm clock/radio is manufactured so that in the event of a power outage, you have the peace of mind that your device will continue working so you never miss an event.
Why is the clock rolling through time and making beeping sounds
I plugged it in with a new battery, a few hrs later it makes one beep every 12 seconds while scrolling through the hours at a high rate of speed.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Try a power reset and see if this resolves your problem.
Remove the AC power and the battery from the clock/radio and then press and hold the Enter/Time Set button for 10 seconds to remove any residual power from the unit.
Replace the battery and then reconnect and switch on the AC power.
You will have to re enter all the information as this should have been lost.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Mark sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 2,383
