Ana içeriğe geç
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
What Could Be Causing a Dead Internal Display?
I recently got a family member's MacBook Pro to recover data from, since it was damaged in a home flood.
It turns out the the computer still works, for the most part. I used Target Disk Mode to initially clone the hard drive, but I plugged in a display into the MiniDisplay Port and the computer actually runs perfectly fine in clamshell mode.
Is there a way that I could diagnose the exact problem, or even repair the computer? Thanks!
Also of note, the green light by the webcam does still turn on, but i've yet to actually test the video feed.
Update: It turns out the backlight is damaged.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
See if you can use a flashlight to shine though the Apple logo (poor mans backlight) are you able to see a faint image of the desktop icon's? If you are you've localized the problem down to the backlight circuit. If not you'll need to pop the bottom cover off to inspect the logic board connection where the display is connected. Take a couple of clear images so we can see and paste them here.
Bu yanıt yardımcı oldu mu?
Puan 1
5 Yorum:
Thanks! I tried shining a light through, and I could see the desktop. Would resetting the SMC help?
tarafından
It's worth a try but I doubt it'll help.
tarafından
Okay. You're right. It didn't do anything. How would I go about further diagnosing the backlight?
tarafından
You'll need to pop the bottom cover off to inspect things. You could have a burnt fuse link or the backlight driver is burnt. This maybe getting on the deep side if you don't have the needed micro soldering tools or access to the parts
tarafından
Hmm. I am no expert, nor do I have the tools or parts on hand to do a lot of extensive work. I can certainly inspect the logic board for damage, but there's not much more I could really do..
tarafından
Yorum Ekle
Yanıtını ekle
Jake sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 87
